Is there a way to publish multiple drawings with multiple layout tabs separately
RubenS1104
RubenS1104
I have multiple drawings that have multiple layout tabs.  Each one has a cover sheet and then either one or two more layout tabs after that.  In the past I would use sheet sets to publish to pdf now I just use the publish dialog box.  I want to do a batch plot of all the drawings but but I don't want them all to be single sheets or just one pdf with all the layouts.  I want to have each drawing be it's one multisheet pdf.  I attached a screenshot of the publish dialog box showing the drawings.  I only added a couple of drawings to show what I am talking about.  I created a sheet set with subsets as well but still can't find a way to do a batch plot and have it create mulitple pdf's of the subsets.
Any ideas?
RobDraw
You will need to do a separate job for each multi-sheet PDF.
Rob
RubenS1104
Thanks for the response.  I was trying to avoid having to publish each one separately but I haven't found a way to do them all at once.  I'll just keep doing them this way.
Thanks again.
