*Solved: Create combined shape & extrude
djeffroy
djeffroy
*Solved: Used 'Join' command to combine shapes.
I'm trying to create a shape made up of arcs / lines and then extrude it to 4" in length. Can anyone give me a quick rundown of how I accomplish this? The shape I want to extrude is shown in the attached image but I don't know the correct process / line types to use that will allow me to combine lines & arcs into something that is recognized as one object and will extrude together.
Thanks!
ara_neresesian
HI
for making a solid you need a closed polyline, and height .
draw your arc and lines, modify with pedit, join all, and then extrude
or you cad draw polyline instance of arc and line.
see attached dwg.
good luck
