Is there a way to keep plot transparency always ticked as default?
alessandrojb
alessandrojb
Hi guys,
Is it possible? Thanks!
cadffm
No & Yes!
1. No, pagesetups are individually
    For new layouts or whole files, use your own template.
2. But you don't need this pagesetup property, take a look closer to
Command: Transparencyoverride<enter>[F1]
Sebastian
alessandrojb
Hi @cadffm
Thanks for your reply.
Would this command affect all the sheets? Because i don't worry about the transparency on the model itself, I just need the transparency to be applied when printing.
Another question, is it possible to export a page setup that you create here (img)? So i don't need to do it every time and I would just need to import it.
Thanks! 😊
pendean
Community Legend
Community Legend
PLOT settings in AutoCAD are by tab by DWG file @alessandrojb Always has been, still is, one setting in one pop-up never translates to all future PLOT command pop-ups.
So.. you'll need to automate with:
1) create named pagesetups in a template file then import when you need that using PSETUPIN command.
2) OR with LISP either as a startup
3) OR as a 'reactor"/trigger for when you start PLOT command.
How would you like to proceed? HELP explains the first option, and lots of tutorials exist on the web too.
