Is there a Toggle to Dynamic Input with regards to continuing angles for successive drawn lines?
eric.remelius
Observer Observer
eric.remelius
Observer
Observer
Let me try to explain what my student asked.  I could not find it.
I draw a line using @5<30.  It draws my line 5 units at 20 degrees
I draw a line from that endpoint using @5<30.  What I am looking for is for that line to be drawn 20 degrees from the end of the previous line segment.
Is this possible?  Theoretically, I should be able to draw 12 segments in succession using that input to create an enclosed polygon.
eric.remelius
Observer
Observer
I had a typo. I meant that the lines will be drawn at 30 degrees
edwin.prakoso
I don't think it's possible.
You can use the tracking setting to help you, but you can't use @x<a as input.
You can use relative polar as guidance, but if you type the angle as you did, it always uses the current UCS.
Cheers,
Edwin Prakoso
