Hi again,
sorry to say, I have to correct my above posts, they contain valid paths for registry as well as for Windows Explorer.
To resume:
I have found these registry paths where filenames from the recent blocklibrary-list can be found:
Computer\HKEY_CURRENT_USER\SOFTWARE\AppDataLow\Software\Autodesk\AutoCAD\R24.0\CoreUser\BlockPreviewUser\Profiles\AN_DevNET\Dialogs\BlockStream\BlockLibraries
Computer\HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R24.0\ACAD-4101:409\Profiles\AN_DevNET\Dialogs\BlockStream\BlockLibraries
And this Windows Folder:
C:\Users\<LoginName>\AppData\Roaming\Autodesk\AutoCAD 2021\R24.0\enu\Recent\Select Block Library Dialog
However, removing any of them or all of them does not clear the list. Also the number of recent files inside the _OPTIONS dialog does not influence the list
I also tried to export the profile as ARG-file ... yes, this contains the list too, edited this list and re-imported the ARG-file and created a new profile from this ... did not solve the question.
So, for now I have tried all I could imagine where it is stored, I have searched the whole registry as well as the whole harddisk for files containing this special filename (mentioned above), however, I have not found any further location where I was able to modify this list.
The only (bad) workaround could be to rename the files, then start AutoCAD and select each of them. That gives you a message, that the file does not exist and if you want to remove it from the recent files list.
Sorry, for now I have no further ideas, hope someone else finds the source of this history, - alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
