Autocad Block Attributes Synchronize Problem
Message 1 of 8
updated block.pngFailed block.pngHi, experts;
I came across a problem while implementing the block attributes synchronization, One day I add 4 other attributes on my block then synchronized it in order that all the blocks of this type have got updated. so there is the problem I found most of the block updated but the others remain unchanged;
I tried purge the drawing, close it then re-open, but all do not work;
Anyone has some idea on this issue?
thanks a lot in advance!
Replies (7)
Message 2 of 8
chriscowgill7373
Have you used the ATTSYNC command?  based on your description, it sounds like it will do what you need it to.  I would post a link to the AKN but I'm on a mobile device so I can't paste a link.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 3 of 8
cadffm
Please, never use special characters in named objects.
Space Point Slash, it isnt a goog idea wot Stylenames, Layers Blocks and AttributTags,
but this is not the current problem.
Is that a "dynamic Block"?
Erase all except one of working and one of problem Insert.
Sebastian
Message 4 of 8
Is there any solution to this problem, because there are hundreds of blocks in my drawing and I already filled most of the attributes I need so it is not good for me to delete them then re-insert, it is totally a waste of time;
I already tried the command of "ATTSYN" many many times;
so what is the practical solution for this issues?
thanks a lot
Message 5 of 8
3wood
1. They may in different block names. Check the block name carefully.
2. Try BATTMAN to synchronize the attributes.
3. Try it in the latest AutoCAD revision - Not sure what revision are you using?
Message 6 of 8
john.vellek
HI @Anonymous,
Can you attach the drawing file to a post? Then, let me know the block you are trying to modify.  I will take a look and see if there is anything obvious that can be corrected quickly.
John Vellek
Message 7 of 8
serkancavuslar
http://autode.sk/2qOn1Yj
Serkan ÇAVUŞLAR
CplCAD / Türkiye
Message 8 of 8
daltond23
Observer
Observer
2025 update. I had this exact issue. I hovered over insert tab to bring down the drop down menu, clicked on the second instance of the block (it had 2 definitions) and clicked redefine only. All of my blocks fixed themselves. Then the other block I cleared from my recent blocks list by right clicking on it. Hopefully this helps someone in the same situation.
