Is it possible to create a form and just let another user input meassures
Hi everyone, i am new in the world of autocad. What i want to do is to create a form or shape, like a round emboss, and then just make it so that when another user opens it, he has to input a series of measures, such as external diameter, radius, etc., and the emboss would change to show those new meassures. I hope i am making myself clear enough for anyone to point me in the right direction, in what sould i learn abaout to make this possible.
Thank you for reading
TheCADnoob
If i understand you correctly this could probably be done with a dynamic block https://forums.autodesk.com/autodesk/attachments/autodesk/154/15712/1/Dynamic%20Constraints.pdf
CADnoob
Thank you, as a newbie, i wasn't aware of this function. I will study more about this.
Best regards
TheCADnoob
no problem 🙂
Dynamic block can be a bit of a dark art at times so if you run into some trouble you might be able to get help on this board or the dynamic block board : http://forums.autodesk.com/t5/dynamic-blocks/bd-p/154
CADnoob
