AutoCAD Forum
Invisible polylines
4 REPLIES 4
kostial.mk
1196 Views, 4 Replies
Invisible polylines
Hello everyone,
I've received a dwg file from surveyors, which contained 3D linework (mostly 3D polylines and 3D splines). Now as I am creating a background overlay which should be 2D I ran across some polylines I cannot see, though I can select them through QuickSelect, or SelectAll. All layers are on and thawned.
The strange thing about them is, that when I run command List on them, there is a line which says "Invisible".
I wasn't able to find anything on Google, so I am turning to the forum. What are invisible polylines? How to work with them and to make them visible?
Tags (1)
4 REPLIES 4
3wood
in reply to: kostial.mk
The command to hide an object is HIDEOBJECTS. It makes selected objects 'Invisible'.
To show them, simply use command UNHIDE.
kostial.mk
in reply to: 3wood
Thank you for your reply, but this is not that. I have tried unisolating, but nothing happend.
3wood
Not sure what is wrong.
Just try following code. Save it as a lisp file, load it with command APPLOAD, and type VISIBLE to show all hidden objects.
;;; Make everything visible. By 3wood 2021.09.21
(defun C:VISIBLE (/ s1 n1)
  (setq s1 (ssget "x")
	n1 0)
  (repeat (sslength s1)
    (vla-put-visible (vlax-ename->vla-object (ssname s1 n1)) :vlax-true)
    (setq n1 (1+ n1))
kostial.mk
in reply to: 3wood
Thank you,
this worked, this unisolated the invisible polylines, though I am not sure, what happend.
Forma Design Contest
