Invisible border layer
Message 1 of 20
A drawing I am working on has a "Border (ANSI)" layer in the drawing that contains the border and most of the title block.  However, the first sheet of the drawing only shows some of the layer.  It shows basically just the words for the layer but nothing else.  All layers are thawed, unlocked, and view port thawed.  The other sheets after the first one are fine and show everything they are supposed to, including the border.  Also, if I copy the border and setup from a different drawing that has it done properly, when I paste it onto the first sheet of this drawing, it only shows the words still and not the border and lines, even though they were selected and copied.  I've attached a picture of the first page on the drawing that's broken and a picture of the first page of a drawing that's not broken so you can see what is missing.  Nothing appears to be turned off or hidden and it seems as if the border is there, just not visible or interactive.Screenshot (2).pngScreenshot (1).png
Replies (19)
Message 2 of 20
user181
Hi @Anonymous,  When in that layout tab and in paperspace and not in the viewport look at the VPFreeze column of the layer manager and see if the layers are frozen there.
Message 3 of 20
Patchy
Double click inside the viewport of 1st sheet to activate the viewport, type in VPLAYER, then T for thaw, enter a *, then hit enter key  a few times.
Message 4 of 20
Like I originally stated, nothing is frozen including in VPFreeze.
Message 5 of 20
This did not work as nothing is frozen.
Message 6 of 20
Patchy
Even when the viewport is activated?  these photos of the UCS icons showed they are still in paperspace.
Capture.JPGPost your actual .dwg and let's see.
Message 7 of 20
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 Can you please share the drawing? If it needs to be private you can email it (them?) to me at [email protected]. Please include a link to this thread in the email. I look forward to determining what might be causing this problem.
John Vellek
Message 8 of 20
cadffm
@Anonymous
"normal" is:
border and most of the title block - placed in Modelspace?
Then jump inside Viewport (command _.mspace) and check VPfreeze - you allready done
border and most of the title block - placed in Layout=Paperspace?
Then jump to paperspace (where you are in your picture (command _.pspace)) and check VPfreeze.
Sebastian
Message 9 of 20
Not quite sure what you mean by "viewport activated".  I double clicked inside the sheet and it allowed me to type VPLAYER and follow the steps you recommended but they didn't work.
Message 10 of 20
cadffm
It should work if the border and title is in modelspace and if vpfreeze is the issue,
but if the border and title is in Layout, you have (vp)thaw in Layout.
Only for testing, thaw all layers in all viewports and layouts:
CTAB
SHT 1
VPLAYER
THAW
ALL
enter
enter
Sebastian
Message 11 of 20
I followed these steps and nothing changed.
Message 12 of 20
user181
Hi @Anonymous,  Where is the border? Paper or Model space?  If it's in paper go to the tab with the missing layers. Go to layer properties manager palette while in paper and not inside viewport. check the VP Freeze column. Then double click inside viewport and check same column.
Message 13 of 20
cadffm
Dozens of people could help in seconds, if you could look into the DWG for you.
Is the linetype of the elements Continuous? Is "Show PlostStyles" enabled in the page setup?
Sebastian
Message 14 of 20
user181
Since all we can do is guess I now say the border is a block separate from the remaining title block text and you accidentally erased it in that layout and you can just copyclip & paste from another layout
Message 15 of 20
cadffm
Or Border+Text(Attributes) and Title is ONE Block and the scaling is very small,
the attributes are not synced with the current blockdefinition.
@Anonymous
If all three items are part of ONE block, select the title-Text and check the X/Y scaling factor.
😄 Competition time, rofl.
Sebastian
Message 16 of 20
Just got off the phone with support.  Turns out the block itself had no geometry and was completely undefined.  I had to purge the block from the document and then find a drawing with the proper block and bring that in.  My guess is whoever worked on the drawing before me deleted something from it and didn't have the knowledge to properly fix it which resulted in an improper title/border block.
Message 17 of 20
cadffm
Good!
"the first sheet of the drawing only shows some of the layer.  It shows basically just the words for the layer but nothing else.  All layers are thawed, unlocked, and view port thawed.  The other sheets after the first one are fine and show everything they are supposed to, including the border. "
So inside the other layouts there wasn't the same block?
Or is it a dynamic block? Then it is possible if the loose the link to the main block definition.
In this case you can have a bigger problem when you tried to edit the block in the feature.
Good luck, read you the next time.
Sebastian
Message 18 of 20
"So inside the other layouts there wasn't the same block?"
No, the effected block was only on the first page.  The border for the rest of the drawing was defined under a different block.
Message 19 of 20
cadffm
The description sounded different, so nobody asked for your block content.
But importantly, the problem is solved.
Sebastian
Message 20 of 20
Yeah I didn't even think to look at the block content. It was a strange error I hadn't seen before and all the normal fixes like you all suggested didn't work so I had no clue where to go, especially not block contents.  But now I know the fix, shall it ever happen again.
