AutoCAD Forum
Integer division and reminder of division for fields formulas.
2 REPLIES 2
615 Views, 2 Replies
Hello.
As you may know it is possible to use some calculation results in the text fields.
For example here I divide 5 by 2 and get 2.5.
Do somebody know if it is possible to get integer division result and also the reminder of the division?
Fox example:
Integer division: 5 // 2 = 2
Reminder of division: 5 % 2 = 1
Are there some operators or functions for that?
2 REPLIES 2
cadffm
If REM isn't a valid function, you can use TRUNC
2.5 - trunc 2.5 = 0.5
EDIT:
In your sample case
5-trunc(5/2)*2 = 1
or
17-trunc(17/2)*2 = 1
11-trunc(11/3)*3 = 2
Or?
Sebastian
in reply to: cadffm
"trunc" is perfect, thanks!
Forma Design Contest
AutoCAD Beta
