AutoCAD Forum
Insufficient Memory To Open Drawing
5 REPLIES 5
845 Views, 5 Replies
Am getting the above error when opening an 85MB file... I usually click on the Ignore button for our VBA or LISP process to continue...
Is there a way to disable the above error message thru AutoCAD system variable, VBA or LISP???
Thanks...
5 REPLIES 5
pendean
Your Windows Paging File is too small: 85MB File will eat up resrouces. Bump it up significantly.
There is nothing to turn off inside AutoCAD to make this problem go away, but if you have a custom AutoCAD profile that does not pre-load add-ons it might get closer to having a 'pure' load..
Turning off ALL background running apps may help too.
in reply to: pendean
thanks dean... by how much would be an appropriate increase in the pagefile that would avoid this prompt???
pendean
1.5x your system RAM is minimum, I would start at 2x and slowly go up by 0.5x
thanks again... we opted to add a routine in our vba command that will monitor the popping of the prompt upon opening any files... this will avoid future changes if larger files will be encountered... 🙂
braudpat
Hello
I hope you are going to run a x64 version of ACAD 201X on Win x64 !?
Because with the x64 ACAD 201X and a lot of memory (16/24/32 Gb) you have almost "no limit" with the size of the DWG you can create/edit/etc ...
My personal GIS/Maps test DWG is about 280 Mb and I can load it with my 32 Gb workstation but 16 Gb memory would be enough !
My Windows Swap file is physically set to 32 Gb but (as said Pendean) it could be more : between x2 & x3 the physical memory is a good value !
With the ACAD 2000-2007, you are x86 - The 32 bits "ACAD.exe" (2000-2016) can use only about 1.3 Gb of memory and after BOUM !
So if unfortunately, you are x86 please "follow" the "ACAD.exe" task with the Windows Task Manager ...
If you approach this value, there is no solution ! Please switch to x64 and a minimum of 8 Gb !
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Forma Design Contest
AutoCAD Beta
