Inserting text into a line
ronnieAPGDY
Observer Observer
Message 1 of 11
ronnieAPGDY
Observer
Observer
Is there a simple way to insert text into the middle of a line as below please?
Replies (10)
Message 2 of 11
Patchy
Put the text on the line then use TEXTMASK, Wipeout; then Group them.
Message 3 of 11
pendean
Community Legend
Community Legend
... or get a custom font with those shapes (arrow and heavy line) and drop them before/after your words.
Message 4 of 11
Kent1Cooper
@ronnieAPGDY wrote:
.... Is there a simple way to insert text into the middle of a line as below please?
To automate the process, you may be able to use my LabelTextTrim or LabelTextMask routines [the first BREAKs the object the Text is planted on, the second MASKS it behind the Text].  They include aligning the Text with what you put it on automatically.
Kent Cooper, AIA
Message 5 of 11
MMcCall402
MText justified middle center with a Background Mask set to 'Use drawing background color'  Set the MText at the mid-point of the line.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 6 of 11
ronnieAPGDY
Observer
Observer
Hi, thanks for this - is TEXTMASK an LT command?
Message 7 of 11
ronnieAPGDY
Observer
Observer
Guys, thanks for the help below - I should have said - I use LT so I dont' think all of the commands are available to me?
Message 8 of 11
pendean
Community Legend
Community Legend
MTEXT has built-in masking.
WIPEOUT command is a core feature across all AUtoCAD variants.
If you are afraid to try the MTEXT built-in Symbols feature I pointed to above 🙂
Message 9 of 11
StephenThomasGrace
If the Line and arrow are always the same length, you could create a block with an ATTDEF for the text.
Use the Multiline attribute feature and you are then able to have a background mask which automatically sizes to fit the text.
-steve
Message 10 of 11
StephenThomasGrace
Try this for example.
Works for me in AutoCAD 2017.
-steve
Message 11 of 11
ronnieAPGDY
Observer
Observer
Thanks all..
Gives me a few options to play around with!
