Inserting a UCS angle value
Hello everyone,
I want to create a text which holds a specific alignment of X angle on UCS axis. Basically I am rotating my view regularly and I want it to understand to always rotate e.g. 45 degrees on my current and not world view. My code as of now is:
(setq gwnia (getint "\n Specify angle: "))
(command "mtext" shelfnamep "j" "tc" "s" "driverstyle" "r" gwnia "w" "0.8" shelfname "" )
I thought about the trans function, but it says it works on points. Basically I don't even need to ask for the user input of the angle at the start of my code, I will always have a fixed 45 degrees on the text that pops up based on my current view.
RobDraw
You should post this question here.
Rob
