How Create a watermark in AutoCAD 2020 DWG file
radoslav
radoslav
How create a watermark in AutoCAD 2020 DWG file  ?
I need advice or application.
Alfred.NESWADBA
AutoCAD does not have a real watermark, but a lot of options to make it look like that.
Easiest way could be to place an image or a text or a block with an attribute in your layout, give it a light color (preferred) or make it transparent and every plot will see that text/image.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
XREF a file with the words you want is the way to do it if you don;t like just writing the TEXT/MTEXT words across your drawing or your plotter driver does not offer it.
