Hi @eddlewington
<<...How do I bring up the Bing imagery within Autocad without importing it?...>>
Regarding you uploaded drawing named Westonbirt Topographical and Utility Survey - Updated APR 2025.dwg You can do this:
1. On your layout tab, activate the viewport.
Image-1
2. With the viewport activated, go to Online Map Panel=>Map Aerial=>Capture Viewport
Image-2
3. You may now change from Map Aerial to Map OFF because you captured the viewport's image--even though it's turned Off, that captured image is now sitting in modelspace.
Image-3
<<Technically speaking the Captured imaged is not an XREF. Your captured image will not appear in the External References palette. If you STRETCH an edge or corner of the image to make it bigger than your original captured area, you'll notice the stretching operation will cover more area and still be geospatially accurate. This behavior is not XREF behavior, it's more like you're streaming pixels over the internet because the coverage area remain live.>>
4. OPTIONAL: In modelspace=>select the captured image=>go to Properties Palette and increase value of Brightness. (Brightness can also be controlled on the Ribbon.) I recommend brightness=80. Brightness values from 60 to 80 will frequently give best results, although some images may vary.
Image-4
Do NOT recommend changing contrast or fade--leave them at their default, 50 and 0 respectively. Also, print a hardcopy before deciding on your brightness value. A hardcopy is an immense help when deciding the brightness. Changing brightness is optional. And don't forget, your linework should bear the load in your dwg, not the image.
Chicagolooper
