inserted image disappear from cad drawing when location of image changed.
Dear all
I created a cad drawing using Auto cad LT 2012. That includes some images ,but when i change the location of images from my drive they also disappear from drawing & instead  of image image reference location is showing like{{C:\Users\obaid.pandt\Downloads}}. i happens with some images  not with all.
but when i put images through snipping tool without saving image and directly paste through [Ctrl+V] it did not disappear.
Kindly tell the reason why it disappear.
i am also attaching some screenshots.
cadffm
Because you added just a reference  to an image file.
The image is not part of your dwg, just a reference object.
If you change the location of the image file, acad can not find,read and display the image information.
When you copy&paste, you create an OLE object, there are two kindsof OLE (embedded and linked).
And the best is: Dont use pixel data, redraw it with vector objects in acad.
Save them as block.
Sebastian
To get your referenced images back: open the "External references" palette (command XREF)
Look for your image name in the list - it probably says "not found" under 'status column. On the lower half of the palette, there is an entry "saved path" - click on it and click on the three dots, a window should open where you can browse to the new file location.
The forum won't let me upload a screenshot for some reason but hopefully this explanation will help.
Help page
Thanks dear.
ennujozlagam
another way is to embedd the image into autocad file, don't need to change image locations anytime. thanks
