Insert unicode control character menu
Can you alter, add to or delete from, the right click "Insert Unicode Control Character" menu?
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Autodesk Community!
From what I understand the Unicode standards are built into the AutoCAD application and are not editable.
If you have a specific standard that is not included but you would like it to be, I encourage you to make the recommendation through the Feedback link in AutoCAD under drop down in the upper right corner.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
