insert survey coordinate points
karolb6URAC
Message 1 of 9
karolb6URAC
The survey provided me with the coordinates of the control points via SKETCH, but when I try to insert them into my AutoCAD plan, they aren’t matching. Could someone help me? Could someone give me their email in case I need a Zoom lesson? I would be willing to pay for the lesson, something not too expensive, but I really need to insert the points!
thank you
Karol Batista
[email protected]
Replies (8)
Message 2 of 9
Wojty1
There are some tools out there to insert Survey Points into AutoCAD.
What format and filetype do the points have (e.g. CSV, TXT, ...)?
Windows 10 Pro 64-bit | Civil 3D 2024+2025 / Revit 2024 (64-bit EN)
Intel Core i7-7700K / 2x 27" / 64 GB RAM / GeForce RTX 3060 OC V2
Windows 11 Pro 64-bit | All Autodesk Products 2023 - 2025
Intel Core i7-13850HX / 3x 27" / 128 GB RAM / nVidia RTX Ada 3500
Message 3 of 9
Valentin_CAD
@karolb6URAC ,
At first glance, you may need to set UCS and PLAN to World.
These links can help:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 4 of 9
karolb6URAC
this is my files but looks like the point 3001 doesn't match ! im so sad and feeling horrible , because im the only woman at job site work with all means trying to do layout , so i really want learning!
Message 5 of 9
CodeDing
@karolb6URAC ,
Something else is wrong here. See my image, both north arrows and building layouts cannot be correct:
Also, when I plot the coordinates and compare them to the ones you have laid out in your drawing, I have no idea how yours were even created, they are not laid out properly (Left are mine, Right are yours):
Seems like there's more information here that we're missing. Or you're taking something in your drawing for granted that you should not be. Rule #1 in surveying: never, ever take measurements for granted; prove everything.
Best,
~DD
Message 6 of 9
karolb6URAC
Can u help align survey points to my drawing ?
Message 7 of 9
CodeDing
No, because it is not possible to do with any of the documents that you have provided
Message 8 of 9
Valentin_CAD
@karolb6URAC ,
I suggest you coordinate with others (if possible, a CAD Manager) to verify/confirm the drawing and the survey control agree.  As noted, the drawing does not seem to be on the correct coordinates, it should be more like the attached drawing.
Emilio Valentin
Message 9 of 9
CodeDing
@karolb6URAC ,
Just a disclaimer, do NOT use Valentin's drawing file to move forward on your project. They plotted your coordinates correctly, but had to use scaling/inferences to align your block to those coordinates. The intent is to Generally show you what your final product should look like. Not to provide an absolute solution.
^^^ Absolutely do this
