Insert other drawing
Mustang69
Mustang69
I am an Inventor user but used AutoCad a lot for about 10years ago.
Now I started to used it again I noticed my old habits don’t work. 😅
For instants previously I could just press “I” to insert other drawing files into the one I work with.
Now that option is gone and there is only blocks to insert.
Older AutoCad I could also “drag & drop” a file into another…..Now it’s just opens the files I drop.
Am I missing some new command or some settings?🤔
user181
The insert command changed to a blocks palette. You can still insert the old way with the command CLASSICINSERT.
Mustang69
Ok thanks!
Any quick command for it or button?
user181
I don't think there is a button but not sure. You can create a keystroke shortcut using Aliasedit command
JohnPachol
Another way is the command DDINSERT.  It is the same as CLASSICINSERT.
Kent1Cooper
Another way is just -I [with the hyphen prefix].  If you then want to navigate to a folder/file location, type in a tilde ~ to get a file-navigation dialog box.
Kent Cooper, AIA
Mustang69
Thanks!
DDinsert will be my choice!👍
Strange that "Insert" been changed! 🤔
