Insert Block In Autocad Using C#
sundaram1087
sundaram1087
Hi
 I tried to insert the block in autocad by Using C# in COM Object method. in that am getting error that "Key not found"
This is my function
public AcadBlockReference NewblockInsert(Double[] Inspt, string BlockName )
double Dimsacle = 1;
AcadBlockReference BlkInsert=null;
try
BlkInsert = (AcadBlockReference)CadDoc.ModelSpace.InsertBlock(Inspt, BlockName, 0, 0, 0, 1);
catch(Exception ex)
MessageBox.Show(ex.Message);
return BlkInsert;
Could you please provide the solution for that
Regards
Shunmugasundaram
ilia.borisov
Are you trying to insert already existing block or you first create block and then try to insert it with that method?
sundaram1087
Hi
Existing block only
Regards
Shunmugasundaram
