Block insert Error??
When you insert the block, it is inserted as a point near the spline or a spline point, not as I would like.
It used to be good, but at some point it happened.
The AutoCad versions are 2017 and 2020.
Alfred.NESWADBA
How do you describe "as I would like"?
Can you upload a dwg-file which shows a good condition and one showing how you would not like?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I'm using a translator. I'm sorry.
If you look at the dwg file, there are two blocks.
The 800,800 coordinates are the coordinates I want and 741,832 is the spline point coordinates.
I have tried many ways, but there is no other way than to delete the AutoCad.
But I don't want to delete the AutoCad whenever there is an error.
cadffm
Not sure what you asking for.
Have trouble with the input method&setting?
Mark the Spline, Click the grip, type i: #800,800<enter>
Is this what you want ???
Please use more words for a detailed description of
What you do, input by input, key by key (Screenshot by Screenshot?)
What you get.
What to expected.
Sebastian
Alfred.NESWADBA
Please write in your own language and we try to translate the text.
From your translated text it is not clear what you try to achieve.
- alfred -
Alfred NESWADBA
cadffm
My mistake. New try:
Mark Polyline, select the grip, type-in #800,800
If this is what you tried? Then it seams you have trouble with How to send coordinates
or How to use and set up Object Snaps.
Sebastian
Thank you for trying to help me!!! I solved error !! I turn off 3DOsnap !!
