New computer fresh install of Autocad 2023.
I use grips a lot to stretch many things from lines, p-lines, dynamic blocks, dims etc. for some reason when I grab a grip, drag in a direction (any direction) and type in an unit of distance and hit enter it doesn't always react the way I'm used to. Sometimes it works correctly say 12" one direction and if I try go back to exactly same spot by inputting 12" back the grip will not end up in the same spot. Also I've noticed that if I wish to draw a dim line or even a regular line for that matter and use a unit of say 5'-0" it will not always be correct. I'm very confused as to what is causing input values to not be accepted correctly. is it a dynamic input setting or something? please help its driving me crazy
thnx
Blake
