Input values not correct
BLAKE_SUSS
Message 1 of 12
BLAKE_SUSS
New computer fresh install of Autocad 2023.
I use grips a lot to stretch many things from lines, p-lines, dynamic blocks, dims etc. for some reason when I grab a grip, drag in a direction (any direction) and type in an unit of distance and hit enter it doesn't always react the way I'm used to. Sometimes it works correctly say 12" one direction and if I try go back to exactly same spot by inputting 12" back the grip will not end up in the same spot.  Also I've noticed that if I wish to draw a dim line or even a regular line for that matter and use a unit of say 5'-0"  it will not always be correct. I'm very confused as to what is causing input values to not be accepted correctly. is it a dynamic input setting or something? please help its driving me crazy
thnx
Blake
Replies (11)
Message 2 of 12
imadHabash
I suggest to turn OFF the OSNAP ( F3 ) and/or dynamic input ( F12 ), any changes ?
Imad Habash
Message 3 of 12
paullimapa
In addition to @imadHabash solutions, I would also turn off SNAP [F9]
Paul Li
IT Specialist
@The Office
Message 4 of 12
BLAKE_SUSS
F12 seems to do nothing at least not that I see at the command propt, but if I go to dynamic input settings I already had everything turned off.  F9 is off as well.
But interestingly F3 did cause my problem to go away. That's a real bummer tho cause I use many osnaps as well as grips.
Is there a reason why osnaps would interfere with input values?  and is there maybe a work around for this so that osnaps can still be used in conjunction with direct input?
Message 5 of 12
user181
Try setting the variable OSNAPCOORD to 2 if it's not.  Then try to draw the line with osnaps still on.
You can also change it in the OPTIONS on the User Preferences tab. Set priority for coordinate data entry to Keyboard entry except scripts.
Message 6 of 12
paullimapa
Did you try just turning off SNAP [F9]?
Paul Li
IT Specialist
@The Office
Message 7 of 12
Kent1Cooper
@BLAKE_SUSS wrote:
.... I use many osnaps ....
Do you perhaps use too many?  Sometimes people just turn on all of the Osnap modes, which is an invitation to trouble or confusion, especially if NEArest is included, which will almost always "win" over others, and prevent you from getting one that you really want.  Does it make any difference if you limit the modes to just a few that you need most often [I like the END/MID/INT/PER combination], and when you need some other one, call for it at the time?
Kent Cooper, AIA
Message 8 of 12
BLAKE_SUSS
F9 was turned off
thnx
Message 9 of 12
BLAKE_SUSS
I have end/mid/cntr/intr/and insrt turned on.
these are the same snap choices I've been using for years? difficult to see how this wld cause issues now?
I will say that it is definitely a problem with the osanps tho, cause my stretch problems go away when it's turned off completely.
This is very frustrating, never had this problem before.....
thnx
Message 10 of 12
user181
You didn't mention if you've tried my suggestion in message 5 to set OSNAPCOORD to 2
Message 11 of 12
BLAKE_SUSS
DING DING DING!!
OSNAPCOORD set to "2" fixed my problem.
What a strange user preference to set but that was the issue.
Thank you (user181)!! I can now keep my sanity.
Message 12 of 12
cadffm
>>"What a strange user setting, but that was the problem"
What's strange about a setting that allows AutoCAD to apply the object snaps you set to the coordinates you specified?
Osnapcoord=1 is the perfect choice in 99.99% cases, value=2 is default and you had changed it to 0 - we don't know why.
Perhaps you played with some unknown scripts, lisps or played in OPTIONS, USER PREFERENCES, Priority for Coordinate Data Entry
Actually, the current setting (value 1 or 2) is strange, the behavior with value 0 is formally correct / but in practice it is almost never desired.
Sebastian
