I've got a linetype issue that's been bugging me for a little while: is it possible to set linetype scales per viewport, or to turn off paper space scaling just for one line/linetype/layer?
I know that you can change linetype scales with various commands, or switch off scaling entirely, but I need to be able to turn off scaling for just one object.
The particular example is for road linemarking. We show a 1:1000 overall plan, then a 1:200 plan for intersection details. I need the linemarking to retain the real world scale/dimensions (eg. 600mm line and 600mm spacing for a Give Way line) at both of those scales, rather than having the spacing scale up to meet the viewport setting.
However, I need the rest of the linetypes in the view to scale up, to keep the plan tidy.
So is there a way to stop just the linemarking lines/layers/linetypes from scaling across different viewport scales? Or a way to control object/layer linetype scale per viewport, like other aspects in the Layer Properties panel.
Darcy
