Inconsistency in measurement in Autocad 2013
Hi There,
I'am using AutoCAD 2013 and while iam measuring objects in model space, I obtain a different measurement between the same parallel lines.
See attached pics. The first one is showing a wierd measured dimension value and I then I have to try a few attempts before getting the correct dimension.
Could some one help me with this issue? Is there some setting that I need to do in measurement options?
Patchy
Same elevation for both lines?
LIST each line and see.
Just found out that these are 3d lines. This drg was made in archi cad or autocad3d or other software. Now I need to get all the objects on a current zero layer to commence my work.
What is the right procedure to do this?
Patchy
Use CTRL+A to select them all
Then CTRL+1 to get Properties Palette to show up
Then click to change them to layer zero.
