importing 3d dwg file into 3ds max proparly
first of all im sorry for my poor english, i hope i can explain myself
problem is whenever i try to import dwg file into 3ds max its import all drawing as one object. i cant seperate nor edit it. ive tried on many version of autocad and 3ds max but no difference. searched it on google and autodesk forums but cant solved it. basicly my question is how can i include AutoCad's drawing to 3dsMax with properly editably?
Johanna_Esteban
Hello @Anonymous,
When importing from 3DS Max, choose "Entity" so that the parts you have in AutoCAD are the same ones that arrive in 3DS Max.
As an additional data, in orange I indicate the values that I usually use to not deteriorate so much the geometry when being imported, you can play a little with them to find the one that best suits your need.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
Hello @Johanna_Esteban,
My english is not enough to explain how thankful I am. Thank you
Johanna_Esteban
Hi @Anonymous,
I'm really happy for you!
Don't worry, the translator will do the work. Smiley Very Happy
Regards, and good day!
Johanna Esteban
