Imported PDF to CAD with text shown like boxes on each.
noli1057
Message 1 of 9
noli1057
To the expert here. This is rarely happening to me when converting/importing PDF to CAD. I want to know how this happen and how you fix this. Please see attachment for your reference. Many thanks to the immediate responses to this issue......
Replies (8)
Message 2 of 9
3wood
Can you check if the "TrueType text" option is ticked when you using PDFIMPORT?
Message 3 of 9
noli1057
3wood, Thanks to your response. I attached my set-up copying your suggestion, and still no success.
Message 4 of 9
Valentin_CAD
@noli1057 ,
Try changing your PDFSHX (System Variable) to 0.
or
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 5 of 9
noli1057
Valentin-WS, thanks to your response. I did the sequence, and still no success. I guess the PDF is corrupt and I will ask the owner to re-print it or send the CAD file if available instead. Thanks anyway.
Message 6 of 9
pendean
Community Legend
Community Legend
Share your actual PDF, someone here can see and explain what might be wrong for you.
Message 7 of 9
noli1057
Thanks Pendean, attached here is the PDF for you to view. Thanks again.
Message 8 of 9
pendean
Community Legend
Community Legend
Thanks for the PDF: it looks like this file never started life in AutoCAD at any point, which may be your challenge
Message 9 of 9
noli1057
So there you go. Ok that confirm my issue here. Thanks a lot.
