Import Total Station data - a problem with points
Message 1 of 12
Dear Community
I am trying to get into Autocad, with aim to work on my fieldwork spatial data collected with total station (the archaeological excavation unit). So I have transformed the csv file (which I've received from the Total) to DXF, then I've put it into Autocad. The problem is, that 1) The size of  points and text is too big, and they overlap, and 2) When I change the size of points and texts, they are separated, I mean after the change of the size, the point number is in different position on the drawing than the point itself. Is there any posibility to solve this problem? I worked on the same data before, in the polish MicroMap software and there wasn't any problem of this kind. I enclose: the screenshots with the problem. The autocad version I am working on is: AutoCAD 2017 - student version, OS is windows 10 home edition.
Big thanks to everyone that will spare some time to help me with this.
Replies (11)
Message 2 of 12
Alfred.NESWADBA
How did you do that?
My way (as long as I don't have AutoCAD Map 3D or Autodesk Civil 3D, which have build in functions to import CSV files) would be to use Excel to convert lines with X/Y/Z to a script with command _INSERT and blockname and if necessary an attribute content for point-number and elevation. Then run this script directly into AutoCAD.
The block itself is then the one that defines the size of the point symbol as well as the size of the attributes.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 12
Thank you!
To transform CSV to DXF I have tried two ways: 1) Polish software WinKalk, and 2) some internet sites that offer such option.
Where do I put the command "Insert"? At the beggining of the file?
What tool in Excell do I use to make this type of conversion?
Thank you!
Message 4 of 12
Alfred.NESWADBA
Well, if they don't give you the result you need then it's up to settings in that tools.
You might send us the DXF files so we can look into them, but as long as these are not blocks with attributes it would be hard to correct later the sizes (and distances between point symbol and text content). Or like in one of the screenshots, if text content is missing you can't recreate them.
No tool, simply formulas which create the syntax you can then use as script in AutoCAD (or copy and paste the content.
- alfred -
Alfred NESWADBA
Message 5 of 12
Pointdump
Lukasz,
"...I have transformed the csv file (which I've received from the Total) to DXF..."
Please post your data. Let's see what you've got.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 6 of 12
Alfred.NESWADBA
please find this video showing which formulas are created in XLS to have a ready to use (for copy and paste) script including attribute handling ATTREQ and ATTDIA to not get the attdia-dialog (has to be reset at the end if you need that).
[video]
Also attached are the 2 files, the excel file with the sample points and the drawing so you have a block-definition that matches with the script.
- alfred -
Alfred NESWADBA
Message 7 of 12
Thanks a lot! I will try to upload my file and I will try to resolve the problem according to the video. The Total Station I've used is Sokkia Set 500, and the data was transferred by using the software dedicated to Sokkia. As I said I had no problem with this using some simpler software designed to create maps. I attatch  the original csv file from the Sokkia software.
Message 8 of 12
Alfred.NESWADBA
here you go ...
- alfred -
Alfred NESWADBA
Message 9 of 12
Thank you a lot, finally it works!
Message 10 of 12
yu85.info
Hi, @Alfred.NESWADBA. I have seen your video and looked at the files.
Tell me please, is it posibble to make the same thing for this XLS file I aatached here?
It has more information that I want to insert to a block.
Thank you!
Message 11 of 12
awesome thread!    anyone know about going from AutoCad to Total Station with points?  😁
Message 12 of 12
TerryDotson
If you have block inserts you should get good results from the built-in DataExtract command to create a CSV file of the inserts/attributes.  If you need more, take a look at MapWorks for AutoCAD, which will do this and a whole lot more.
