Changing the UNITS in a dwg-file does only describe "distances in the drawing have to be understood in Meter" (or what ever setting you have selected).
Changing the UNITS does not influence your coordinate input.
If you want to change your geometry size when you change your UNITS setting you can use command -DWGUNITS ... this command gives you the chance to scale the existing geometry. But take care, if you have already created layouts with viewports and then use the scale option in the -DWGUNITS command you'll need to update your layouts too.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2024------------------------------------------------------------------------------------
(not an Autodesk consultant)
