AutoCAD Forum
Import PDF
2 REPLIES 2
juliareceputi
152 Views, 2 Replies
Import PDF
I need to help to import a pdf and use the image as a block, right now when I try to import it either doesnt show the image, or it shows the image with a white background.
2 REPLIES 2
pendean
in reply to: juliareceputi
Which command are you using to "import" the PDF?
Can you show your work? Share your DWG and PDF file here.
paullimapa
Your pdf may be a raster file with no vector information. You may have to just attach the pdf instead
Paul Li
IT Specialist
@The Office
AutoCAD Inside the Factory
