Edit dwg like text file.
valotaire_emile
Message 1 of 11
valotaire_emile
Is it possible to edit a dwg or dxf as a text file or export all text and attributes to an excel or .txt file and re-import the file to update the dwg or dxf drawing
Replies (10)
Message 2 of 11
Valentin_CAD
@valotaire_emile ,
Explore these options:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 3 of 11
cadffm
you can save dwg files in ascii-dxf files (editable like text files too),
but you should search for tools to do this job.
See Emilio above
Sebastian
Message 4 of 11
valotaire_emile
When I open the dxf 2018 on notepad++ it is not possible to find readable text
Message 5 of 11
valotaire_emile
Here is the result
Message 6 of 11
pendean
Community Legend
Community Legend
DXF is coded to draw what you see on screen in a CAD program: learn the code and explore using SEARCH tools to find "text" in that file to edit as you need to do.
Here are reference guides to that DXF code if you are interested:
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-3F0380A5-1C15-464D-BC66-2C5F094BCFB9
https://images.autodesk.com/adsk/files/autocad_2012_pdf_dxf-reference_enu.pdf
Message 7 of 11
cadffm
Hi
If not, you saved not as ascii DXF
(but also in binary dxf, you will be able to FIND your Textstrings!)
binary DXF, first line:
AutoCAD Binary DXF
ascii DXF, first lines:
0
SECTION
2
HEADER
9
$ACADVER
1
AC1032
EDIT to your last post: This is an ascii DXF, you just looking at the wrong place (line).
Use CTRL+F to find your values..
But again: This is not the way you should go (you should have the knowledge about .dxf structure well, otherside you will create a damaged file)
The way to go: 3rd party tools!
Sebastian
Message 8 of 11
cadffm
For Attributes
Command: ATTOUT and ATTIN (if Expresstools are installed)
Or more modern and powerful  - https://www.lee-mac.com/batte.html
For (M)TEXT, you need other tools.
Use your favorite search engine, I am sure you get success
Sebastian
Message 9 of 11
valotaire_emile
(Batte) lisp works well for attributes, but my problem is with text and mtext.
Message 10 of 11
cadffm
I noticed all 3 and I answered => "
@valotaire_emile  schrieb:
.. all text and attributes
@cadffm  schrieb:
For Attributes
Offtopic
Please use the Reply button, so we can see to who you replying.
Sebastian
Message 11 of 11
valotaire_emile
Thanks for the advice, I'm not very familiar with the platform yet.
Also, I found the solution by asking several people's opinions. You have to use VBA to extract all the text and attributes with the position in the drawings to Excel and vice versa.
The only problem is that it requires VBA programming in Autocad.
