AutoCAD Forum
Import PDF
4 REPLIES 4
458 Views, 4 Replies
Import PDF
We have a PDF file (see attachment). Import this PDF into Autocad 2018-2019. Graphics were imported fine, but the text had a problem: some of the text was in the form of squares, the rest of the text was in the form of primitives AutoCAD. What should I do to have text instead of squares? The text that came in the form of primitives,  AutoCAD can't recognize even at a threshold value of recognition of the 1%. What to do?
Tags (1)
4 REPLIES 4
qnologi
vinodkl
The converted the pdf text will be displayed as square if it doesn't support that particular font. Try to edit the text and change the font to different one(fonts prefixed with "@" would display the text).
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
in reply to: vinodkl
It does not work.
in reply to: qnologi
We did it. After that we got the text from AutoCAD primitives. We tried to recognize it by AutoCAD and it didn't turn out. "The text that came in the form of primitives, AutoCAD can't recognize even at a threshold value of recognition of the 1%" Why?
AutoCAD Inside the Factory
