Import and display X,Y,Z points from Excel file
Message 1 of 9
Hello  everybody,
I have some troubles to find the way to import points in AutoCAD 3D projects. I have 1400 points in Excel file with columns ID, X, Y, Z,. I would like to display them with 2 labels (ID and Z).
I know there is scripts showed on web but it doesn't work for me.
Herewith my Excel file.
Thank you for your help
Replies (8)
Message 2 of 9
Hi @Anonymous
Normally points import  fails with number formats: decimal point or comma refer to an dot or comma respectively. Check "Number format" in your Windows, which decimal separator use:
Message 3 of 9
tcorey
Do you not use Civil 3D?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 4 of 9
Thank you
Yes I have checked that AutoCAD need . as decimal separator.
Yes I just found Civil 3D as option. I am gonna try that. Is this soft provide .DWG as output file ?
Message 5 of 9
АлексЮстасу
To display points, you can make a block with the necessary attributes, and load your data with the necessary labels using Lee Mac's PointManager, PTM - http://www.lee-mac.com/ptmanager.html.
You can also download using Civil - as written by .
You can import and Map (/ Civil) 3D - MAPIMPORT.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 6 of 9
tcorey
Yes, Civil 3D uses .dwg, the same as plain AutoCAD.
Tim Corey
Redding, CA
Message 7 of 9
OK thanks, I got Cicil 3D.
I have lot of trouble to import my set of topographic data.
It should be easy but it's not, for me
My Excel file is :
first column : description of the point (sometime empty) alphanumeric
column 2 : X numeric
column 3 : Y  numeric
column 4 : Z  numeric
column 5 ID   string
what kinf of format shoul I use ? I tried but I always have error messages about my input file.
Thanks a lot for your help
Message 8 of 9
Here is my import windows
Message 9 of 9
tcorey
Instead of the column for Point Number, use Point Name. Point Number does not allow alpha-numeric, but Point Name does.
Tim Corey
Redding, CA
