Images not showing in paperspace
officeYAKEG
Message 1 of 14
officeYAKEG
Im attaching  JPGs in the paper space but when I plot to print. The image disappears.
The layer is on.
The color is white.
Also the font plots weird too:
Replies (13)
Message 2 of 14
ChicagoLooper
Would it be possible to upload a screenshot of your plot dialog window?
Also, upload a screenshot of your image folder that shows your image extension, i.e. jpeg, tif, png, and the image size in terms of KBs.
Chicagolooper
Message 3 of 14
ben.saa
Autodesk Support
Autodesk Support
Message 4 of 14
Valentin_CAD
@officeYAKEG ,
Read the suggestions from these links:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 5 of 14
jrreid
You didn't put them on Defpoints layer or a layer that is set for No Plot.
For the Fonts. When you open your drawing, hit F2 and see if there are any substituting of fonts.
If there is then you don't have that font installed on your computer.
Hope this helps.
JRR.
Message 6 of 14
officeYAKEG
Message 7 of 14
officeYAKEG
Message 8 of 14
officeYAKEG
I tried and its not working 😫
Message 9 of 14
ben.saa
Autodesk Support
Autodesk Support
If you load fewer images will it work?
-could you share the drawing/ the image I'll try loading
Message 10 of 14
officeYAKEG
It has to do with the Plot and publish options because I dont have that problem with other files. 3D 3.JPG
Message 11 of 14
jrreid
Select the Image that prints out ok and then select all of your images.
Are they on the same layer?
Close the drawing and then open using Recover.  Who knows maybe there is a corruption issue going on.
Hope this helps.
JRR.
Message 12 of 14
user181
In your plot settings UNCHECK the "Hide paperspace objects" option on the right side under plot options.
Message 13 of 14
officeYAKEG
Oh my god! That was it...
Thank you so much for your help
Message 14 of 14
jrreid
LOL!!!!
Just had to comment.
It is always that way when you find the small checked or un-checked items.
I guess it is the beauty of CAD.
