Is it seriously not a way to adjust when using the tool IMAGECLIP? Once you've clipped you can never make a new dot or remove a dot in any other way than doing the whole thing over again?
if do you mean to adjust image size you can do it by grips (when select without command).if not please describe your problem with more details.
>> Then it appears as dots all around the image <<
these dots not suppose to appear!! the only dotted that i see in my own practice is when i select the image and this is visual dotted frame not more.would you describe the clipping procedure please and show us some image?
>> The dots I am referring to are just the blue squares that are visible when the image is marked <<
this squares called Grips..
you mean that your clipping not fit with your polyline shape then i suggest to use CLIPIT command. this express tool will help you more for clipping image with curves and lines.
hope it's help
I suggest to post your question in this AutoCAD for MAC which you will find more help...
when you did run _IMAGECLIP and assigned a polyline to build up the image clip border you can modify the polyline (there you can add vertices with the standard grip functionality. When you have finished modifying the polyline you have to restart command _IMAGECLIP and use option "New boudary" ==> now select the modified poly.
As far as I can see when deleted the objects that build up the boundary you can't add new vertices to the clipping boundary directly on the image.
- alfred -
