My new company uses image files that are inserted into layout, but the images keep disappearing on me even though the source files aren't being moved. Any ideas on how I can correct this?
Kevin
HI kev65,
Sounds like an interesting issue. Is it possible to attach some of the files involved so I can investigate and try to duplicate the issue on my side? Things I am going to look for include:
file type and size
file locations
file path type
locked layers/viewports
security/permissions
I look forward to helping you with this problem.
They disapear when I reopen the drawing, there are just names of the files where the picture should be.
HI kev65,
I haven't seen an update on your post so I thought I would check back to see if your problem is resolved or to see if you need additional input. If you can attach the files it would help in figuring out what is happening.
The only thing I figured out is the images HAVE to be in the same folder as the drawing. I had them in a sub-folder and for some reason AutoCAD loses track of them, even though they were in the same location when I attached them.
I was hoping to find a way to permanently attach images, as they are the part manufactures information and certification, and I won't need to change.
Thanks for the help with this!
Hi kev65,
It sounds like you are having problems with your file path using the Xref manager. can you take a screen shot and show me the file path information to your images?
