I am about to start working on a project where I will have maybe 2 or 3 people doing simple drawings for me and was trying to think of a good way to send the drawings back and forth.
Has anyone else come up with a good plan on how to do it?
I was thinking about opening a dropbox account and sharing it with my co-workers.
Steve
Solved by john.vellek. Go to Solution.
Solved by pendean. Go to Solution.
Solved by leeminardi. Go to Solution.
Dropbox is probably the easiest since it automatically synchronizes and it's free. Just make sure only one person is working on the files at a time then you won't run into problems. Once synchronized, that person will have to stop working on it, until the next person is done and the files are synchronized again.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Dropbox is good and reliable. You do have to be careful not to delete the "cloud" copy when you delete a copy from your hard drive. File syncing is fairly fast. It is not free. A 3 person business license is $12- $15 per month.
If you are just going to send a few files back and forth you might consider Google Drive which is free.
Hi @spaulus
You might consider trying A360. I like to load files to my A360 drive and then share with others. They can view the files, add comments, download them and even use versioning.
HI @spaulus,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
after i create a block library, can i send the block library to a friend and will they be able to create a tool palette and use the blocks off the block library or do i need to send all the block also?
Steve
Hi @spaulus,
You can certainly send them the block library instead of the separate block drawings. You should also write up a description for them that describes how they might extract the blocks or create a Tool Palette using Design Center.
