i need some help
i need some help
Message 1 of 8
i need some help
Hi, everyone, my name is Fernando and i have a problem, that i have to fix.
Right now i make a 3d wire frame and i need to do some analysis in ANSYS (static and modal) i know that can do this in mechanical simulation but this is a requirement.
the question is, i dont know how can import the 3d wire frame to ansys. I´d like to know which is the extensión to do this.
i really appreciate the help that someone can give me. and i gonna be very gratefull
Replies (7)
Message 2 of 8
imadHabash
you can know all the extensions that can both Ansys and AutoCAD can deal with from Export command from AutoCAD and Import (Attach Geom) from Ansys. when the dilaog appear go to Files of type  and see all extensions.
Imad Habash
Message 3 of 8
Alfred.NESWADBA
I would start with DXF as this is the most common format for data-exchange of simple geometry.
As your files do not contain 3D-Solids but just simple lines it should be ok to import a DXF in Ansys (if it can live with lines).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 8
Hi, i´d like to give thanks you for your answer, i do what you write to me, and exported the file from autocad as iges extension, but does not work when i try to load the geometry into ansys, shows me error...i don´t know what i have to do.
give me another clue please...the version of autocad is 2014 and Ansys is 16...
Message 5 of 8
Alfred.NESWADBA
And the error message is ....?
Have you tried the DXF approach?
And have you checked if Ansys can work with simple lines?
- alfred -
Alfred NESWADBA
Message 6 of 8
Hi, finally i imported the file to ansys as iges extension, thank you for answer and cooperation.
and i´d like to know if in Autocad can i asign a cross section to the elements from the wireframe.
thankyou...marry cristmas
Message 7 of 8
imadHabash
you can get sections from SECTIONPLANE command.from 3D Tools tab
Imad Habash
Message 8 of 8
when i was asking about if in autocad can give a cross section to a wire frame like example a W shape profile. something like this, sorry if i cant explain better before,  because of i don´t have right now a solid model to make a secction...
