i need help
i need help
ebram_shenouda
Message 1 of 11
i need help
ebram_shenouda
can someone help me draw this picture in autocad ,
thank you
Replies (10)
Message 2 of 11
TheCADnoob
Id try tracing it.
Id recommend trying to get a better picture. My guess is that's not an option as this looks like it was taken from an Instagram post.
Using the image you need to transform the picture so that it can be traced. I used gimp here to do that.
Once I have the image 'squared' up. Ill brin it into AutoCAD to trace.
When tracing I like to use a high contrast color for my line work
Tracing this image will not give an exact copy since the image has been transformed. Its recommended that the trace just be used to create an accounting of the shapes present and then line them up correctly.
Once you have the items traced you can use the surface tool to create surfaces of everything, then you can extrude the items. once you have 3D solids you can use the subtract tool to create your 3D Model.
CADnoob
Message 3 of 11
Kent1Cooper
@TheCADnoob wrote:
.... Once you have the items traced you can use the surface tool to create surfaces of everything, then you can extrude the items. once you have 3D solids you can use the subtract tool to create your 3D Model. ....
Easier than that:  Once you have it traced, assuming the perimeter and all the internal triangles/quadrilaterals are closed shapes, PRESSPULL will make the whole 3D Solid with all the holes in it, all at once.  No need for Extrusions of a lot of pieces and then Subtracting those from an overall Solid.
Kent Cooper, AIA
Message 4 of 11
ebram_shenouda
i tried to draw it but i feel it wrong i think it can better than this
Message 5 of 11
Brock_Olly
Looks like the shapes are all aligned with one another on some kind of grid.
Start by drawing straight grid lines vertically and horizontally.
Every angle you make looks like it should be 45°
In your example you created each shape individually, which is why it looks off.
Message 6 of 11
ebram_shenouda
can you help me with this ?
Message 7 of 11
Kent1Cooper
They are clearly not all at orthogonal and/or 45°-multiple angles in the original image, or these would all be parallel:
I think it should look "off," because what it's an image of is "off."
Kent Cooper, AIA
Message 8 of 11
ebram_shenouda
so it should look like what i draw ?
Message 9 of 11
Kent1Cooper
If you traced it accurately, why not?  [I did not analyze your drawing in comparison to the image in detail, not having something to rectify the image as a basis.]
By the way, don't use the "Reply to the topic..." slot under the last Message.  Anything entered there shows as being in Reply to Message 1 and its author [in this case, yourself], so it's not clear to whom you're Replying, or sometimes about what [unless you include a quotation].  Instead, always use the REPLY box at lower right within the Message you're Replying to.
Kent Cooper, AIA
Message 10 of 11
ebram_shenouda
ok bro thank you and can i get help in the drawing ?
Message 11 of 11
TheCADnoob
to me it looks like you have the ability to do what you need. It may still require clean up, but you are just about there. Im not sure what you need help with.
If you are looking for someone to do the work for you, you can check out the services marketplace and see if you can hire someone there.
https://www.autodesk.com/support/partners
CADnoob
