I do not want to plot the Dimension Nodes at the end of the extension lines
Hello 🙂
I have tried, and tried, and tried to search for an answer about this... and I have come up with nothing.
I have a dimension style and a dimension on a layer for annotation in my model space. When it is plotted to a PDF using the DWGtoPDG.pc3 it prints the nodes as dots.
How can I print the dimensions without the nodes printing as well??
Would really appreciate any help!!! I've exhausted my search skills...
M_Hensley
Normally the dimension nodes are on the defpoints layer and will not plot. The only time I have seen them plot is if the dimensions are exploded. Are you creating exploded dimensions? (DIMASSOC set to 0)
pendean
Community Legend
Community Legend
Did someone explode these dimensions first? That's your problem.
If not... Share a DWG file with this problem, let's all have a look.
Hi M_Hensley!
Thanks for your reply 🙂
I am not creating exploded dimensions - so I'm perplexed as well.
Thanks for the reply pendean!
I'll try and see if I can't upload a dwg today.
