I cannot erase some shapes in AutoCAD 2020
Message 1 of 31
Hi All,
I can't seem to edit/erase some shapes in AutoCAD 2020. After pressing the erase button in the modify panel, the shapes and the enter button, nothing happens. The shape is still there. I'm not sure why.
Thanks for the help.
Kind regards,
Ian
Replies (30)
Message 21 of 31
Alfred.NESWADBA
do you have Map3D or Civil3D?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 22 of 31
Whenever I try to delete it, I only get 'command: _erase 1 found'
Message 23 of 31
Nope. The drawing I have just now was done by somebody else.
Message 24 of 31
BUMP
Need help.
Message 25 of 31
Alfred.NESWADBA
Can't you ask this person to remove or explode this object?
>> BUMP.
Kidding?
How much more suggestions within an hour are you expecting than you have got?
The solution would be much more easy if you could send us the dwg-file, maybe delete everything else (so only the critical object is visible), save this file with a new name and upload this file.
- alfred -
Alfred NESWADBA
Message 26 of 31
cadffm
@Anonymous  schrieb:
BUMP
Need help.
after 10minutes silence?
cheeky..
And are you really not abler to upload a copy with the proxy elements only?
Set PROXYNOTICE = 1 and open the file, there is a list
of one or more missing applications - share the application- and company names.
May i ask "what represent" the object?
a wall, a gear, a tree ?
Sebastian
Message 27 of 31
Alfred.NESWADBA
you might also try this free (great) plugin:
https://apps.autodesk.com/ACD/en/Detail/Index?id=1498235021060360128&appLang=en&os=Win32_64
- alfred -
Alfred NESWADBA
Message 28 of 31
s.borello
Check sys var "pickfirst" and set it to 1.  Ensure layers are not locked.
Message 29 of 31
No worries. It's working now. Thanks for helping anyways.
Message 30 of 31
Alfred.NESWADBA
May I ask what the solution was now?
- alfred -
Alfred NESWADBA
Message 31 of 31
imadHabash
it will be great if you share with us the solution . 🙂
Imad Habash
