I can't understand why presspull doesn't work as it should
Hi!
This post is continuation of
http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016/presspull-unexpected-result/m-p/5876754#M1...
I have the same issue agian.
I need to create extruded circle in the center of solid.
When I do presspull or extrude I can see result in 2D wireframe,
but I can't see that in others types of View
I aligned UCS before extrude solid.
After extruding Solid - the body of guitar,
I am trying to use and presspull.
It still doesn't work.
All ideas are appreciated.
The file is attached
Thank you!
undefinedundefined
Replies (29)
@dbroad
I do appreciate your help!
dbroad
Thanks for the kudos.  In the second attached drawing, those are not circles.  Those are circular surfaces.  There is a difference.  They seem to work fine in the second drawing though.
Create a screencast for your process, starting with 2d geometry for the guitar and post it.
Architect, Registered NC, VA, SC, & GA.
these are not surfaces.
this is circle having thickness of 0.05.
Please advise me on program for screencast
yes, I posted the 3 objects in order to show you the steps
1)I create box
2)I draw circle
3)I do presspull
it works as it should do
dbroad
Direct your browser to screencast.autodesk.com
Focus on the guitar problems, not on the second drawing, which seems to work for you.
HA-HA-HA!!!!!!!!!
I was blindly followed the instructions of the tutorial.
And created region on the surface of the guitar.
That was the reason I couldn't see the result of presspull and extrude.'
Thanks to each of you!
Spoiler
Spoiler
@dbroad
Thank you for your simple explanation!
I used  this tutorial and it is much more complicated!
https://www.youtube.com/watch?v=Uf2-bP4S_XE
Thanks again!
thanks for suggestion this is help me for 3D guita
It happens to me as well every time I try to extrude an polyline with, say, a separate circle in the middle. I do this for welded base plates where I need threaded holes for that base plate. And it doesnt work. It works in wireframe, the two separate object moves together and the extrusion is created with the same command at the same time but when I change to realistic or any other view type the hole only shows as a separate object inside the polyline and not as a void. So if its not precious AutoCad's fault then who's? And this has been like this since 2009. I wonder when they're going to get around to fix this bug ... and trimming hatching and insulating objects in block editors without the program crashing.... etc.
A good workman is not obsessed with a faulty tool. He replaces it with one that works. Its otherwise called sentimentalism.
nischhal1023
Community Visitor
Community Visitor
my presspul donot locate the region inside the line
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
