AutoCAD Forum
I Can't Scale Down
5 REPLIES 5
3045 Views, 5 Replies
I Can't Scale Down
The dimensions in my file are way too large to scale down. My dimensions are measurements like 4.19418e+22'-0". I'm trying to scale that height down to 10' but autocad displays an "extremely small scale factor ignored" message. How do I fix this?
5 REPLIES 5
Try first to check the units in the file as well as the display scale in right-down corner of the workspace.
Alfred.NESWADBA
If such high coordinates exist I assume the geometry you have is not accurate any more.
You might upload the dwg-file so we can try to scale it, please let is also know a reference dimension and the value it should then be as new length.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Yeah, the units are set to inches and the scale is 1:1.
in reply to: Alfred.NESWADBA
Hi, thanks so much for your help. The file is attached.
Alfred.NESWADBA
You have not applied any reference dimension, so I used _SCALE multiple times, selecting all objects, basepoint 0,0,0 and scalefactor 0.000001 ... until it's more close to a usable size.
The scale command should now work well so you can use scale with reference and enter a length you know.
- alfred -
Alfred NESWADBA
AutoCAD Inside the Factory
