AutoCAD Forum
I can't run the program
7 REPLIES 7
Message 1 of 8
798 Views, 7 Replies
 Hello everyone. The problem is when I try to start the program, it shows the screen with autodesk emblem and nothing happens then. I have windows 10 (64 bit). Before some rewewal, autocad worked correctly. Is there any way to figure it out?
7 REPLIES 7
Message 2 of 8
Alfred.NESWADBA
If you can tell us what was meant by "some renewal" we might be able to help you figure it out.
Important too: what is your AutoCAD version and, as you write "Windows 10", let us know if the update to Windows 10 was one of the renewals.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 8
in reply to: Alfred.NESWADBA
Hello, I will try to answer: the autocad version is 2017. I don't know how to find out the specific version of this soft. My windows 10's version is 1607 build 14393.447. Thank you in advance.
Message 4 of 8
You are right, I had the windows 8, then I was offered to upgrade to windows 10 for free via e-mail.
Message 5 of 8
john.vellek
Hi @Anonymous,
I would consider removing your current installation of AutoCAD 2017 using a clean uninstall.
Then a reinstall following Best Practices. Make sure also to install the service packs and update available from here.
John Vellek
Message 6 of 8
Here Renewal means Autodesk have some new update.and they are trying to notify you.
Thats it.
Message 7 of 8
I give a attachment.I think you will be clear.
Message 8 of 8
in reply to: john.vellek
Hello, John! Thank you very much. It's working now!
State of Sustainability Webinar
AutoCAD Inside the Factory
