- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello.
At least there are 2 post in a forum concerning this same question, but at both cases answers do not relate to the question. This is my try :-).
I can retrieve objects Hyperlink parameter using Data Extraction - no problem.
But Hyperlink parameter is missing in Field->Object parameters.
Is there any way/code that can be put in Fields Expression to make a field display Hyperlink (or Hyperlinks 'Text to display' to be specific)? That would be a real gamechanger as objects Hyperlink parameter could be used as objects description/name/symbol (whatever you intend). This would work something like text/string parameter in eg. BIM - say "Comments" parameter.
Before You give a obvious solution:
I know I can make a Block of object and give it a name, or define a block attribute with name/comments but I don't want/need to make blocks of each and every line/polyline/hatch I want to name.
I also know that I can make a Field with "Linked" category - but this field is standalone - it doesn't point to any object, so it's useless.
I know that I just can make a plain Text/Mtext next to the object and put it's name by hand 🙂 but it's not the point.
Shame that in 2021 AutoCAD entities don't have a readable comment parameter by default.
Please help me (and many others) as this capability should be in AutoCAD for years now.
