AutoCAD application icon not showing when attempting to open file from Windows Explorer
Ait-Tek
Ait-Tek
Hi Guys,
any ideas why my auto-cad drawing is not showing the dwg icon in file browser. see attached. I am running windows 10 and office 365
thanks in advance
Andy
@Ait-Tek,
Topic Title has been changed by @Tiana_Y for better findability. Original: Application icon not visible.
imadHabash
try  right click >> Properties >> General tab >> open with ( select AutoCAD application ) .
Imad Habash
Ait-Tek
Hi Imad,
i had already tried that, see first image below, it shows the logo but not on my files in explorer, when I go to change (see second image) not many choices and the autocad cad one doesn't work either
vinodkl
See if this helps: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/DWG-file...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
ennujozlagam
you can refer to this LINK and see if helps. thanks
or
  1. In Windows Explorer, right-click a DWG file and choose Open With > Choose another app (or Open With > Choose default program in older Windows systems).
  2. In the next window, select "AutoCAD DWG Launcher."
  3. Select the checkbox for "Always use this app to open . ...
  4. Click OK.
facturasFE4UU
Changing the default app from the context menu didn't work for me but doing the same  from Windows Settings > Aplicactios > Default Apps sorted out the issue.
