AutoCAD application icon not showing when attempting to open file from Windows Explorer
Ait-Tek
5,808 次查看
5 条回复
1 条消息(共 6 条)
Ait-Tek
Hi Guys,
any ideas why my auto-cad drawing is not showing the dwg icon in file browser. see attached. I am running windows 10 and office 365
thanks in advance
Andy
@Ait-Tek,
Topic Title has been changed by @Tiana_Y for better findability. Original: Application icon not visible.
0 个赞
5,809 次查看
5 条回复
回复 (5)
2 条消息(共 6 条)
imadHabash
try  right click >> Properties >> General tab >> open with ( select AutoCAD application ) .
Imad Habash
0 个赞
3 条消息(共 6 条)
Ait-Tek
Hi Imad,
i had already tried that, see first image below, it shows the logo but not on my files in explorer, when I go to change (see second image) not many choices and the autocad cad one doesn't work either
4 条消息(共 6 条)
vinodkl
See if this helps: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/DWG-file...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
5 条消息(共 6 条)
ennujozlagam
you can refer to this LINK and see if helps. thanks
or
  1. In Windows Explorer, right-click a DWG file and choose Open With > Choose another app (or Open With > Choose default program in older Windows systems).
  2. In the next window, select "AutoCAD DWG Launcher."
  3. Select the checkbox for "Always use this app to open . ...
  4. Click OK.
0 个赞
6 条消息(共 6 条)
facturasFE4UU
Changing the default app from the context menu didn't work for me but doing the same  from Windows Settings > Aplicactios > Default Apps sorted out the issue.
