Is Hp laserjet Enterprise 700 M712n and M712dn compatible with autocad 2018 & civil 3d & newer, would it work on window 7, 8 cause most computers have window 10, the rest have window 7.
Solved by john.vellek. Go to Solution.
Solved by DarrenP. Go to Solution.
you asked this question already: https://forums.autodesk.com/t5/autocad-forum/hp-printer/m-p/8238415#M947184
DarrenP
Hi @Anonymous,
I suggest that you visit a local dealer and take your laptop. You can set up a couple different environments on your laptop with the different applications installed so that you can test. I suggest that you bring some drawing files with a variety of linework, hatches, image attachments, PDF attachments, OLE objects, and wipeouts.
Test the various types so you have a better comfort level for the printer you are trying to select.
Make sure also to check how well the drivers behave with each Operating System.
