AutoCAD Forum
HP Printers
2 REPLIES 2
291 Views, 2 Replies
HP Printers
Is Hp laserjet Enterprise 700 M712n and M712dn compatible with autocad 2018 & civil 3d & newer, would it work on window 7, 8 cause most computers have window 10, the rest have window 7.
2 REPLIES 2
DarrenP
you asked this question already: https://forums.autodesk.com/t5/autocad-forum/hp-printer/m-p/8238415#M947184
DarrenP
john.vellek
Hi @Anonymous,
I suggest that you visit a local dealer and take your laptop.  You can set up a couple different environments on your laptop with the different applications installed so that you can test. I suggest that you bring some drawing files  with a variety of linework, hatches, image attachments, PDF attachments, OLE objects, and wipeouts.
Test the various types so you have a better comfort level for the printer you are trying to select.
Make sure also to check how well the drivers behave with each Operating System.
John Vellek
AutoCAD Inside the Factory
