Solved by arshadmirza786. Go to Solution.
Sorry for delay
I was waiting may be Autodesk in collibration with HP issue some hotfixs
I think
1 HP up loaded the drivers in Apr 2013
2 Windows 8.1 update 1 was in Apr 2014
3 AutoCAD 2015 has been in Apr 2014
and these 3 friends should look in to matter and get a remady in near futuer
It in reply of "Autodesk Community Team" which ask to "mark one as an Accepted Solution"
Thanking you
We have the same problem. Windows 8.1 Pro, AutoCAD 2015 LT, DesignJet 800 42. We can't select the plotter from selectbox in printer dialog. But from AutoCAD 2014 LT everything's ok on the same computer, and also from other apps. So for now it's only problem in AutoCAD 2015.
I am using 8.1 op sys with AutoCAD 2015, AutoCAD LT 2015, and AutoCAD 2014. The HP DesignJet 500 25" printer is only working with the 2014 version. One of my fellow instructors at college is experiencing the same problem.
I believe AutoCAD 2015 versions have a printer problem on Windows 8.1!
Dean,
I'm hearing of more people who are also having this issue when printing. This user has the HP 800, and they do have the latest drivers from HP. The user in this case was using the old .pc3 plotter wizard and getting an error "Test Failed" then "Bad System Driver". I had him try to connect to the Printer without using the Wizard - just choosing the HP from the System Printer list in the Print Command. He gets an error that refers to a DWF when he tries that, which seems very odd.
Can we revisit this issue? He is able to save to PDF and then print the PDF to the HP just fine. As it stands the user cannot print to the HP 800ps from 2015 at all, even though he could from 2014.
have the same problem (Win 8.1, HP DJ 500, ACad 2015).
Problem fixed after disabling digital driver signature control.
1)download latest HP drivers
2)install them, it ends with "problem with digital signature" - ignore
3)disable control - http://download.hiti.com/Files/Others/How%20to%20disable%20digital%20signature%20enforcement%20on%20...
4)and plotter works for me now
We have 5 workstations with Win8.1 and ACad Electrical2015 - all of them works fine now.
according to ur instruction I have diable the signatures
But still the message recieved is attached here with
I have got no change in my position
may be u r lucky and it solve ur problem
